2016 Titanium HB 1.6L 111k miles HELP
Well, if you didn't live so far away...I'd love to stop by and review what you're up against and either throw a good-bye party and throw dynamite at it to put it out of it's misery - or - "Gee - where does this wire go?" - moment and hook it up, start it, and the thing will run like it did before that wire (or whatever) caused this messy backup...
So to review, the oil change problem seems to be fixed, the Intake seems to be cleaned up. Spark plugs were goofy, but you're getting a fresh set - good idea - the jumping the battery moment though - has me wondering if the wiring from that red terminal is messed up or you may have a fuse blown - either in the Alternator/Starter post (about 250A) or the main post of 450A that goes to both that starter alternator post and the breakout buss that the EPAS, MAIN and 2 AUX work off of.
The part I'm talking about is under the Red Cap...
The Photo below is from my archives in the Gallery section. I've touched up the photo to add in the graphics to help you locate what I'm talking about...
You say you can't start the car, but if you get Dash lights - this terminal may have a blown fuse - just see if you can find 12V on that post shown above. If not, then presume you have a blown circuit in that battery terminal - and you just need to check for a blown fuse. Then just get to a Ford dealer or any auto parts store and see if you can locate a fuse to repair that thing.
To inspect that fuse - there is a plastic cover - just gently pry it off using a small blade screwdriver - it will reveal a fuse bolted to that section using two small hex-head screws - just unbolt it and remove it so inspect - if it is blown - replace it. But remember to clean off any corrosion - and install the new one and replace that plastic cover.
Daveb40258
LOUISVILLE
KY
2016 Fiesta Titanium Hatchback
Thread Starter #22
Ok a lil confused. I think you may have my thread confused with the "oil change" guy. My problem started with the passenger side mirror torn off and the battery drained that night and needed to jump start it the next morning.
The poor running ECT...started either that day or next.
Now, 3000 miles before the mirror incident I changed the oil but put 5w30 in it and used a cheap Fram oil filter.
The battery connections are fine and after cleaning the painted ground connection, I have continuity throughout.
I should have been more specific regarding the no start. She really really really tries to start. Sometimes it sounds like "yes she's gonna start" only for the battery to not have enough juice to keep going.
So, she has fuel, spark, and compression.
I value your advice and like I said I'm pretty good with auto repairs. It's the troubleshooting these newer cars that frustrates me. Especially when OBD says "unable to complete test related test either failed or was incomplete" paraphrasing. Would be nice to know which component it's talking about.
Just so I understand your previous reply about the J engine. Are you saying that when one of those sensors fail it could just default to CMP sensor (as an example since they are "the same" )?
Thanks for the fast reply
I really gotta get my baby going now,(and u may laugh), today the check engine light just tripped on the BMW 🤔🥺. I already know it needs a tune up I just can't wait to pay the BMW owner price for parts 😕.
Edit: regarding the old plugs. I cleaned them, re gapped them to . 030 and those are the ones in it right now. I'm putting my money on the battery and plugs.
As far as living too far... You do realize the Kentucky Derby is Saturday. Just saying.
Daveb40258
LOUISVILLE
KY
Thread Starter #23
Hey Andy,
You'll never guess what I found in my phone today?
I have track recordings and notices (fault codes)
From my Torque Pro app that I didn't even know existed. They go all the way back to 2021. I guess when you activate "track record" it saves the info in a .csv XL file. I just have to pick out the obvious changes and I hope we can pin point the culprit or culprits.
Oh ok! When you said there was no start, I do see where the Starter and Alternator terminal can blow its fuse - usually due to something in the wiring along the loom, that debris got thrown at, got struck by or cut into the wire leading to a branch for both.
There have been times where the "car dies" and someone can't find out why until they investigate the terminal box that looks like the one shown above. If the battery seems ok, and the Alternator produces power, then why the "low battery"? Much of this is due to poor connections - the biggest problems have been with corrosion - so it's good to know you're making an effort to fix much of the glitch problems these cars have.
They tend to run fine until the electrical - either by corrosion or by insulation -start to breakdown and poor contact will lead to bigger problems later on.
Since were on "J" engines - the issue really goes back to how the system interprets errors and tries to localize them - as you said earlier - the failed or "incomplete" is usually a result of intermittent and erroneous readings from too much noise on the lines the systems needs to see to find the results of it's diagnostics. IF loose connections or poor corroded wiring are in the way - the system sees it like a type of "noise" it can't finish the job due to not knowing what is considered a "fair value result".
(Not from the programming side, just the test can't complete is the sensor is masked in noise trying to deliver a result)
There vehicles are Drive By Wire so you move a pedal, but the sensor in it, tells the system to move the plate of the throttle - so the two have to talk and see clean results - potholes, poor roads and salt with a lot of rain in-between add to this problem.
IF you understand the Drive by wire process, the issue of having the system try to see and review problems is a little harder as time goes by and the vehicle ages
Daveb40258
LOUISVILLE
KY
Thread Starter #25
Makes sense. So I downloaded csv viewer from the Microsoft store as it puts everything in a nice little readable format. Best of all it was free.
So I don't know if I can post csv files or not. Maybe you can send me a private message with your email and I'll share them in Google drive or Dropbox. Which ever.
Ok this is a fiesta forum but I thought you'd like to know I put some 93 fuel and some injector cleaner in the BMW and not only did the light go out but she runs like new. Most inexpensive repair ever lol.
