- Messages
- 180
- Likes
- 157
- City
- Not-US
- State
- Non-US
- Country
- Canada
- What I Drive
- 2011 Fiesta SE
Welcome to JPs General Tech on Waxes and Sealants!
Refer to my JP's GT Tech Introduction to Detailing for more information on basic detailing tools and items.
Before waxing or sealing a car, it is imperative the car be super clean first or you risk doing irreversible damage to the paint on the car.
Please see my JP's GT How to Properly Wash Your Car.
The misconception all over town is that petrol heads and detail geeks wax their cars to make them shine and pop. I would agree that a well detailed car is a beautiful sight. The way the sun reflects off the surface of the paint will accentuate the lines of the car. Paint will appear deeper, thicker and more luxurious. The glass like reflection will bring colours reflected from the surrounding environment adding interest and intrigue.
But that is just icing...side effect...fringe benefit. The reason to wax or seal is to maintain that look for longer, potentially for the life of the car. Although not as exciting as the results, that is the reason many of us wrench. We maintain our mechanicals with oil changes. We maintain our cars capabilities by replacing worn parts. Our cars would not last if we didn't. We maintain our paint by washing regularly and protect with dedicated coatings.
The paint is the outer layer saddled with the job of being the barrier between the fragile body and trim pieces and all the evil in the world. Paint accomplishes this with a thickness of only 4 to 6mil (1 mil = 1/1000 of an inch or a thou), about the thickness of copy paper. And Spiderman thought times were tough!
By applying a protective coating, washing requires less effort to remove dust/dirt, insect strikes, bird droppings, sap, tar, fall out, brake dust and if you really pissed off your neighbourhood eggs, coke, coffee and the occasional ball sack. All these evils will over time degrade the look of your paint, and time is the biggest factor. If left unattended, you run the risk of scratches and paint damage when dust and dirt get rubbed on the surface of the paint. Sap, insect and bird remnants can burn into the outer layers of the paint as they are acidic in nature. Tar, fall out and brake dust can embed into the paint and discolour it. Sunlight only speeds up the damaging process. Eventually your paint will look like this...
To avoid this, a thin layer of protection needs to be added. Starting with a good clean paint job is ideal. The cleaner the paint, the longer the coating will last. The more contaminants under the surface of the protection the harder it is for the coating to cure and attach.
The first step is to clean your car well. Many will use Dawn dish soap for the process of stripping the paint. If you are planning on further preparing your surface with a pre wax treatment such as claybar treatment or compound buffing (more on this in future threads), Dish liquid will work. However, if you feel the need to just wash and then wax, I would suggest you pickup a dedicated stripper soap.
Cleaner Waxes - A cleaner wax can also be referred to as a "One-step" wax, don't let that fool you. These products will use chemical cleaners or even mild abrasives to scrub the surface of the paint with out cutting into the top coat. The purpose of a cleaner wax is to clean up minor oxidization or surface residue such as bug guts or sap. A cleaner wax will not cure blemishes in the paint such as scratches or marring. A cleaner wax could follow a claybar treatment on a car that required extensive claybar work. Think of it as a product that prepares the surface for a quality coating such as a proper wax or sealant. Generally the lasting ability of a cleaner wax is short. It is also important to follow a cleaner wax quickly with a proper product application as allowing the cleaner wax to cure could affect the longevity of subsequent layers.
Longevity - Low / Appearance & Shine - Med / Hydrophobic Properties - Med
Expect protection for days to weeks.
Spray wax - Sometimes these will get used because the process is easy, spray and wipe. Spray waxes and Quick Detailer/Detail spray can by some companies be labeled as the same product, and generally have minor differences. However a dedicated Detail spray will have a cleaning element with light protection, whereas a Spray wax would be designed to just protect. This muddies the field when shopping. Don't expect a spray wax to last like a paste wax or sealant. An important part missing from the spray wax process is the friction and heat that activates the components found in liquid/paste waxes and sealants. This process is the working action needed to thinly workout the layer of protectant before curing. Spray waxes can be useful, I like to use spray wax after washing wheels. Wheel cleaners are hard on waxes and sealants, it provides a layer of protection after each wash. After correcting an area, if you don't plan on waxing immediately, a spray wax can provide short term protection to carry through to proper reapplication.
Waxes - This is where we begin to divide the field. A wax is based from natural ingredients such as Carnauba, a vegetable based product from the leaves of the Carnauba tree. They can also contain bees wax, Montan extract and fatty oils. Usually there will be petroleum distillates, which will flash off before you buff out the wax to a luxurious shine. Some products will use natural polymers and resins to increase the hardness and durability of the wax. A wax is what gives you a show car deep wet look shine, however natural waxes generally don't have long term lasting protection and will require periodic recoating. Generally a paste can be a little harder to spread out properly leading to wax being removed at different stages of flash off/hazing. These come in paste or liquid forms.
Longevity - Med / Appearance & Shine - High / Hydrophobic Properties - High
Expect protection for weeks to months
Sealants - Some people misspeak and call Sealants "wax". Sealants are much like a wax, they both apply in the same manner. You can apply a sealant with the same types of applicators or DA polishers, and remove with MF towels. However, Sealants are made from synthetic ingredients. Sealants look like a form fitted thin glass coating all over your vehicle. The longevity of a sealant is where they really shine. With advancements in the science of sealers, some advantages include ease of use, many can be applied in slightly less ideal situations compared to a traditional wax. The synthetic polymers can greatly reduce surface tension leading to a cleaner car for longer, and less effort when cleaning. These will always come in liquid form.
***Some products can still include the word "WAX" although they are accepted as sealants***
Longevity - High / Appearance & Shine - Med / Hydrophobic Properties - High
Expect protection for months to a year
Ill include this, although it doesn't fit into my idea of waxes and sealants...
Ceramic/Nano coat - These came about relatively recently in the timeline of detailing. Many people think that a Ceramic treatment is "set it and forget it". There is proper care and treatment even for a ceramic, it is not indestructible. Unlike any of the previous coatings, the application is a 2 to 5 year investment. Recoating may also be required. A Ceramic coating bonds with the paint surface and can protect against light scratches and improve surface hardness.
***One caveat, If you require paint correction (ie: scratch or chip) you can not spot treat the area. The panel will have to be stripped of its ceramic, repaired and recoated.***
Conclusion - There is an endless list of waxes and sealants from many different suppliers. I would encourage anyone to do research on what will suit them best. In the end, the products that will require the most work, usually give the best rewards. I have an arsenal of products that I use depending on the cars use, service life (summer/all year), paint colour and type etc. There are products designed to be used on specific colour cars. Some products are designed to provide long lasting protection while others will get that bird bomb off and protect your finish for a week or two, giving you time to redo the panel properly. Once you have built a good base with a quality coating, sometimes a quick recoat might only be needed on a small section. Pay attention to how the car shines, and how the water beads, these are clues to how well your finish is doing. Waxes and sealants work best when you up keep the coating periodically, don't wait till its all gone. Keeping up with the coating is easier than starting over.
Thank you,
JP
edited for updates
Thank you,
JP
edited for updates
